- Dec 27, 2008
That was my initial plan was to use power resistors to setup a constant load. This was changed once I realized that I could target specific wattage points in a real world situation. My data is significantly more relevant being in situ than based purely a heat parameter. Mounting, CPU geometries, heat soak (thanks earthdog)... All of these things plus more are giving me numbers that I can desicively say can be replicated in a retail product.
And Blaylock, I am only running hwinfo64 for temps, and I have disabled hardware monitoring in aquasuite in an attempt to partially mitigate the problem. Turning off the aquasuite service and closing the software gets be back to an idle of 30-31C. I am assuming that removing the restrictive fitting would get me back to 28-29C. I have contacted Aqua Computer and asked if there is a way to reduce the amount of resources drawn by their software, and I hope to get an answer from them sooner rather than later.
I need to find a way to pick up some competing AM4 blocks without spending a lot. Used would be best. Also, once the stuff for a very well known company is done cutting this week, I will have machine time. Finally. I could get all the data in the world, but I am only testing one setup. Even though I am giving my best effort to collect data points objectively, there are still too many variables that are intrinsically linked to my specific set of hardware. Really looking forward to getting some more eyes and hands on a beta N2.
And whenever you make changes to he system you are adding to that variable list. I could be wrong but I think your are setting yourself up to generate a lot of irrelevant detailed data that most custom loop builders either won't be able to understand or won't care about. They just want the bottom line: "Does thenrz' block give lower temp than block x,y,z already on the market?" And it is unlikely that anyone else will have the same loop as you with regard to the various components it contains anyway. So it might be a good idea to enlarge your beta testing pool to include more individuals who are willing to swap out their water block with yours so that you can get delta results from a variety of system combinations.
All you need are deltas so "dance with who you brung." And I guess I don't understand your focus on generating 200 watts of heat from the stress testing. Isn't that an arbitrary number? Why wouldn't 145 watts do?
If you acquire some used blocks produced by various manufacturers, make sure you clean them thoroughly to remove the gunk buildup internally.
