- May 23, 2001
- Asteroid B-612
Despite popular belief, I don’t know everything. So this dictionary may have a few holes here and there that I need other members to fill (mostly about water-cooling). So PM me your written or quoted entries and I’ll add them the the Dictionary. And PLEASE PM me a correction if anything here is wrong.
This dictionary was inspired by the somewhat complete mod dictionary at Directron. But I wanted to let everyone (and me) add their 2 cents to the whole thing as a resource for new members. Some entries were gathered from various sources here and there (mainly to save my fingers from falling off).
Those sources being
- How stuff works
- Many different dictionaries
- Several different technical sites or product brochures
It's painfully simple to back-track to find where each definition originally came from.
I will be including pictures and thread links as I find them…
Entry ratings
Under each Mod description there is a difficulty rating ranging from 1, to 10.
DIY difficulty is how hard it would be to accomplish the above listed mod by "Doing It Yourself"
CAP difficulty is how hard it would be to accomplish the above listed mod by finding, pruchasing, and installing a "Commercially Available Product"
USAGE TIP: You can save yourself alot of time if you use the SEARCH function of your browser (CTRL + F in Internet Explorer). If you want to find a specific term, search it and the browser will find and highlight the nearest entry. Press F3 to move to the second instance.
It saves alot of time!
Terms currently covered… - | 7v Trick / Voltage Mod | Air Brushing | Acrylic Windows | Aluminum Cases | Anodize | Appliqué | Backlighting | Badge Backlighting | BandSaw | Barbs | BayBus | Bench Grinder | Bezel Painting | Bios Logo | Blow Holes | Briefcase Mod | Cable Sleeving | Case Badge | Case Mod Gallery | Case Painting | Case Windows | CFM (Cubic Feet per Minute) | Cold Cathode | Common Screw Sizes | Common Wire Sizes | Dba (Decibels) | Digital Baybus | Dremels | Drill-Press | Dynamat | Electro-luminescent (EL) Cable | Etch / To Etch | Fan Control | Fan Tails | Fan Size Adapter | Fanbus | Fan Grills | FSB (Front Side Bus) | FSB Divider | F@H (Folding \ Fold) | Game Mods | Glowire | GPU |Grommets | Hard Drive Mod | Heatercore | Heatsink Fan Units (HSF) | HeatSpreader | Holesaws | Hyper LEDs | Jig Saw | Keyboard Mods | Lapping | LCD | LEDs | Luggables | Case Mods / Modders | Neon Tubes | NIC Mod | NorthBridge | SouthBridge | OBO | OEM | Ohm's Law | OS Mod | Oribital Sander | Overclocking | Passive Cooling | Peltier (TEC) | Potentiometers | PSU (Power Supply Unit) | Quiet PC | Radiator | RAMsinks | Reservoir | RheoBus | Rheostats | Rounded Cables | Rubber Gasket | RMA | Sand Blasting | SawZall | SETI (SETI@home) | Shrink Wrap | SLURP | Spiral Wrap | Split Loom | Soldering Iron | Stealth Mod | Table Router | Temperature Sensing | Temperature Shutdown | Thermal Adhesive | Thermal Paste | Thermal Tape | Toggle Switch | Tools | UV Additive | Water Block| Water Cooling | Window Mod | YGPM | Zip Ties |
7v Trick / Voltage Mod --- These days noise is a big concern for many new system builders. One major source of noise in a system is the fans. The 7v trick allows you to quiet down a noisy fan (while reducing airflow a bit).
Your normal computer fan operates on a standard 12v power source from your power supply. Three voltages are supplied by the power supply: 12v, 3.3v and 5v. The two voltages that are easy to get at are the 12v and 5v. These are supplied on a standard 4-pin power lead. Two wires supply the power to a fan. The voltage supplied to the fan depends on which of the 4 wires is used from your 4-pin power lead is used. The normal arrangement is for the yellow wire and the adjacent (ground) wire to be attached. With this you get 12V power to the fan, which is the difference of the wires. The 7V mod is accomplished by using the Yellow 12V wire and Red 5V wire instead of the standard 12V and GND. With 7V, the voltage is dropped 41.7%. This reduction of voltage corresponds to a significant drop in noise. (Note: Noise is not 100% proportional to voltage.)
Easy to use adapters are now commercially available to perform this voltage trick without doing any wiring yourself.
(DIY: 3/10. CAP: 1/10).
Air Brushing --- Once the domain of T-Shirt vendors, Air Brushing brings case painting to a new level.
Using airbrushing techniques a skilled Artist can permanently add a unique image to your case. The result could be astonishing. It brings the concept of "custom casing" to its highest level. What could be better? Custom painting is now available commercially in additional to the pre-determined paintings. (DIY: 8/10. CAP: n/a)
Acrylic Windows --- Acrylic (mistakenly referred to as plexiglass) windows are the most common windows installed into a case. But Polycarbonate (Lexan, mistakenly referred to as plexiglass) is much easier to tool material and is more suited for the abuse that a case window may endure during installation. Lexan isn’t as scratch resistant as Acrylic, but I don’t know anyone who frequently keys their case window or has birds running into it…
Pre-made window kits typically come in reverse L, oval, rectangle, round, or U shapes. These are now available either in do-it-yourself kits or as factory-made side panels. Cases with factory-made side windows are now also commercially available.
(DIY: 5/10. CAP: 4/10)
Aluminum Cases --- Aluminum cases are a new trend in case design. Aluminum cases are lighter then traditional steel cases and have slightly better cooling abilities. Many aluminum cases feature the bright silver "brushed aluminum" look. The popularity of these types of cases is continually rising as more people wish to make their case more transportable and cool looking. It is worth noting that a few very determined modders have also taken to fabricating their own cases out of aluminum. Generally this is very expensive and very time consuming vs just buying a case. Some people claim that Aluminum cases improve cooling efficiency because they conduct heat better. But if examined logically, Aluminum cases are generally laid out more professionally and have better airflow.
As always, you get what you pay for.
(DIY: 10/10 CAP: 1/10).
Anodize --- The process of Anodizing turns the top, thin layer of a aluminum into aluminum oxide. This is used to protect an aluminum surface from oxidation. While that is all good and well, the interesting application of anodization is that it allows a long lasting, metallic color to being evenly applied to the case. Most case manufacturers currently only apply a color to the outside of the case. An increasingly common mod is to anodize the inside of the case in either the same color as the outside of the case, or a different contrasting color. This is especially effective when used with case backlighting and a window. An example is the Directron SF-201B. Many anodized aluminum cases are now commercially available. Anodization is difficult and dangerous to do personally because of the chemicals and equipment required for the task.
A number of online retailers sell pre-anodized products (so-trickcomputers.com is the only one I can recall)
(DIY: 10/10. CAP: 1/10)
Appliqué --- An appliqué is a sticker like image that can be applied to a case window or dark colored case size (case tattoo). When used, an appliqué makes it look like you have an image etched or sand blasted into the window.
Appliqué are particularly effective when used with case backlighting. You can do this yourself if you can find the proper material for it. (DIY: 8/10. CAP: 2/10)
Backlighting --- Lighting is an excellent addition to a case that has a window, or one that has a translucent or semi-translucent component.
Backlighting in a computer case is typically accomplished via the use of a Neon / or Cold Cathode lights. (DIY: 6/10. CAP: 3/10)
Badge Backlighting --- Badge Backlighting is a specialized form of lighting for case badges. There are two methods of accomplishing badge backlighting. The first method involves putting ultra-bright LED (HyperLED) behind the badge in such a manner that the light will shine through the badge. The problem with this is that most case badges are metal backed, and light will not shine through them. A variation on this method is the use of an electro-luminescent square that can be placed behind the badge. The square provides slightly more even lighting.
BandSaw --- A toothed metal hoop that is tightly driven over two spring loaded wheels. Band saws are perfect for making straight or semi-curved cuts in metal. This is the preferred tool for trimming heatsinks because it allows for finely cut control and give much smoother edges than a Dremel can.
Barbs --- Barbs are the metal hose fittings attached to Water Blocks. Their design prevents leakage and slipping. Properly fitting barbs onto a water block proves to be one of the more difficult feats of building a water block.
See also: Water Cooling, Water Block
BayBus --- The BayBus, which was popularized and coined by Cliff Anderson, is a relatively simple device with a simple purpose. A BayBus is a 5.25 bay mounted device that provides: 1) A method to attach and power fans (usually bare wire fans), 2) dual or triple position switches (1 per fan), 3) 1 LED per switch to help indicate on or off. A BayBus allows you to easily control several fans in order to control noise level. They are especially effective in the 3-position switch variety as you can have the switch perform the 7v trick for you. (With three positions you would typically use 12v, off, 7v).
Bench Grinder --- A bench grinder is a heavy-duty tool that allows you to precisely grind down or polish a metal object.
Bezel Painting --- Bezel painting is the act of painting a drive bezel to change its color. Bezel painting is one of the most common mods as it allows you to use beige or other colored drives with a silver, black or other colored case.
Bios Mod --- Perhaps the trickiest mod, the bios mod allows you to change the bios logo / text that you see when you start the computer. The danger of this mod should be very apparent, if you mess up the bios you may end up rendering a good motherboard useless. This mod is becoming much easier over time as motherboard manufacturers see the demand for it. Some well known motherboard makers such as Asus and FIC now have bios logo programs available for their products that make the mod relatively safe and easy. Usually such programs are free and sometimes they are even included on your motherboard driver cd. (DIY: 10/10 CAP: 2/10).
Blow Hole / Blowhole --- A blow hole is a additional fan slot added to a case to increase the case's cooling capabilities over stock. There are typically three places blow holes are added to a case: 1) Top of the case. (Chimney fan). Since heat tends to rise an exhaust fan at the top of the case makes sense, however the top of the case is also the hardest place to add a blow hole since not all case tops are flat, and most are not removable. 2) Side panel, near CPU. A blow hole placed near the cpu's HSF can have the great effect of either supplying the HSF with cool outside air, or exhausting the hot air off the CPU. (It's best to match the direction of the CPU fan. If it blows onto the heatsink then intake, if not then exhaust.) 3) Side panel, card area. A blow hole in the card area can aid the cooling of hot devices like Video Cards.
(DIY: 4/10 CAP: n/a)
Those sources being
- How stuff works
Entry ratings
