Method: Crayon to fill the L1 laser pits and the surrounding ones too, to be safe. Auto window defogger paint to connect the dots. Used a safety pin to apply and acetone with Q-tips to clean mistakes. Scotch tape to mask. I also used grounding heel straps and a wrist strap, a 5x magnifying glass, and a mag-lite flashlight.
Pitfalls: Must clear crayon wax from the L1 contacts with pin or exacto. It helps to use several thin layers of defogger paint, and press it flat. The paint seemed to lift up when I was trimming its edges sometimes. Take your time. I did this twice and spent at least half an hour each time.
I did this yesterday, so I can't vouch for the longevity or safety of the crayon method. Some people seem to think the crayon wax will melt. At 105 F on the core (probably cooler on the L1 area), I doubt it.
Edit: Finished tweaking my new cooling gear set up and now the cpu idles at 31 C or 87 F. Let's see that crayon melt now! Load temps to come once I get windows working again.
