- Mar 26, 2012
- Edmond, OK
- Thread Starter
- #461
Radiator cabling work last night. This finishes up all the fans!
I start with doing a rough layout of how the wires should connect. Then I strip insulation at each "join" point, and open up the middle of the wire and wrap the joining wire around it.....
Then each join gets some solder. I'm notoriously bad with the solder iron....but have improved somewhat from my last build....
Then each solder join needs protection so it won't be touching the other wires underneath the sleeve. I use this tiny little heatshrink from Bitspower that barely goes over the cable. Very tight fit. I forget exactly what size this was....
But here it is compared with some normal heatshrink. You can see it's much smaller.
Here's what it looks like once it's shrunk on the wire....
Couldn't resist a shot of a perfectly crimped Lutro0 male fan pin on the Lutro0 wire with the Lutro0 crimper. His tools really work well together.
Skipped a few picture opportunities along the way....but here is the finished radiator cabling. This is the front flex bay area 240. Minimal wiring. Nice and clean.
Ready to move on to the pumps!
