I've got a Barracuda 7200.11 1TB drive that appeared to die. Then I started to look up the symptoms and found that there is a huge 40-50% failure rate in these drives, particularly if it's made in Thailand and has tge firmware SD15.
Seagate still aren't forthcoming about the obvious failures which is usually on boot tge drive spins up normally but the bios hangs trying to detect (on most motherboards but mine recovers and continues).
It turns out rebooting is the cause. The drive gets stuck in busy mode and refuses to respond.
I've found a fix out there and I'm going to try it out as soon as I can find out more, as I've got data I desperately want back!
