- Feb 18, 2010
So the ASUS card is a PCIe card that lets you mount 4x M.2 NVMe SSD's? That's cool!
Yeah, nearly 13GB/second read and write (would be quite a bit faster on gen 4 PCIE)
There are still some on e-bayNice to see some old school components getting put to use. Yes, please share more pictures if you can.
Almost wish I didn't get rid of my old DFI Nforce2 board.
Thank youNice loop! Specs on the system?
This dude is down with the thickness!!Got new EK 360 XE for the bottom today.
Nice one
I like the coolant flow design on these new GPU blocks.
I always worry about the coolants with dyes like these mist effects. They look great but usually don't last long enough in perfect condition. There are stains on tubes or reservoirs (the liquid's level makes a stained line). It's a bit sad to see that happening after putting in so much work. I hope it won't be a problem in your build and it will look great for a long time.
I will probably make a simple build soon as I need to refresh the Intel test rig (mainly for RAM, storage, and maybe graphics card tests). I'm trying to cut costs, and I wanted to paint an older radiator, but I changed my mind about the case and will reuse the one that I already have, but I will need a 280mm rad, so I will just buy a white radiator and close the topic. Simple loop like EK block/res/pump combo+280mm rad for i7 13700K CPU and nothing else. Thinking about it for 2 weeks probably made me save $200.
So far any staining has not been an issue. I have seen that with the colored coolants in the past, but this EK mystic fog I have not yet had any issues. I have had it in the loop for about 4 months. When I added the EK GPU block, i just drained it into my collection bottle with clean equipment, then poured it back in after reassembling the loop.
I did replace all of the PETG tubing with newly bent acrylic tubing (I like the clarity of it over the PETG). So perhaps it will have some plasticizers leach, but I am really just not sure on that.
If nothing else, let the new acrylic get what it needs to, out, gunk up the loop in the next few months, then I tear it down for a deep cleaning and put fresh clear fluid in. I don't typically use the flashy showy fluids, but the kids wanted to see the mystic fog in the loop.
I have changed my case to a Corsair 7000D. Here is a pic of how my loop looks now.
I did have the GPU vertical, but the block is not very good at clearing the bubbles in it, and it really blocks access to the bottom NVME's and connectors at the bottom of the board. It makes draining the loop easier like this too. It does look better vertical, but for me is not very practical.
Post magically merged:
I like the hard tubes, but had a disaster in the past and destroyed my GTX1080ti and Asus z390 board, so i will stick with soft tubes now.
Nice loop though, but did you have any problems with bubbles in the GPU block?
