Themaltake Blue Orb?
Sinkhole
Hamden, CT
Ive got a Blue Orb hangin around was just wonderin everyones thought on using it for the Northbridge on my A7N8X-D motherboard. Yes-No-Maybe. Just wonderin.
Sink
Ffats
Illinois
Don't see why not. You could probably get a little more mhz out of the FSB with a blue orb (or any active cooler really).
I'd probably mount a 40mm on top of that passive cooler on the Asus. I don't like the noise or look of the blue orb. Just looks cheap, IMO
sandman001
Just Freeze It
my blue orb almost killed my geforce 3. the power cord went up into the fan, dropped 10mhz off the core o/c. I now use a stock AMd heatsink on my geforce 3.
It will work with the fan off.
wannaoc
Buried in UPS packages
I currently use one on my 9600 and it works like a charm. If I remember currectly the blue orb is actually a NB cooler so it should work fine, I did lap mine so the paint on the bottom wasn't blocking heat but thats it.
