ThemoEngine by thermosonice, Max Load temps are 50C
Angry
Im curious, I bought a Themo Engine hs/f by themosonice.
Well it works okay, Max load temps for my 1.2 Athlon at 1470 are 50C, According to Sisoft, I cant get VIA hardware monitor work on this Asus A7V-133...
I took off teh crappy fan that came with it cause its just scouldnt psuh enough air, so Now I have my EverCool 7000rpm on thier and load temps are down from 55C...
But an Idle of 45C is still to high for me, Even after I started overclocking it it the temps didnt change...50C is still max load.
I have good themal paste on the chip and I have the heatsin seated properly...
Is the the performace I should expect from it?
ocean
Chicago Illinois
Those temps seem kind of high. Assuming that the thing is installed properly, you may need better airflow through your case.
What's your case temp? I used to run a Thermoengine and delta fan on a 1.33ghz athlon @ 1.50ghz and I don,t think I ever got over 40c under load at ambient temp 22c.
Hope this helps.:D
Acko
UK
Hi Angry
I bought one of those heatsinks after reading all the hype, & was very dissapointed at the results I got. My readings were 50C at idle for a 1 Gig Athlon, sold it on to a friend at work, he used it on a Duron, it was better suited for that.
Acko
