- Mar 13, 2001
- Connecticut
I have read that it is bad to put too much on the cpu,
I think I put more than I should have.
Seeing as the heatsink is putting pressure on the cpu wouldnt the extra just push out the sides?
Like when you put glue between 2 boards and clamp them?
I would hate to have to order more artic silver unless you think I can just remove the excess if I need to.
Grr... can't edit the subject ohh well its compound.
