- Aug 20, 2003
I agree with EarthDog here. Out of the 10+ thermal compounds I've tried, Kryonaut and Conductonaut have been second and first (respectively) for me in terms of performance. I've compared them on laptops, desktops, delids, and gpus... I think either something was wrong with your application or mount.
Having said that, I haven't used Thermal Grizzly pads before, only Fujipoly. Thinking about it though, perhaps you had the wrong pad thickness and that was keeping it from making good contact? I'd be curious how the Conductonaut works with the Fujipoly pads. It's not only the thickness that matters but the compress-ability. Dried thermal pads makes me think they are a higher W/mK. In my experience the higher the W/mK, the less compressible they are.
- - - Updated - - -
One would think that but reviews consistently put Conductonaut ahead of Cool Laboratory Liquid Ultra/Pro. I'm sure the ratios are different. I only had a small tube of Cool Laboratory Liquid Ultra at one time and it performed well, but I never had conductonaut at the same time to compare it with. Even Silicon Lottery switched over to Conductonaut.
- - - Updated - - -
Conductonaut is almost only made of gallium/indium. There is nothing special in it. Nearly every "liquid metal" is made of the same stuff. They only mix it and put different label.
Other thing is that using liquid metal on a GPU is a stupid idea. One thing is that you need perfect contact and other thing is that liquid metal reacts with everything near like aluminum and some other metals.
