Thermal Pad Removal
q149
Japan
How do u remove your thermal pads or compound? ive been scratching it off with my fingernail, but this only gets the job part way done..
ed8150
Baltimore, MD
somthing flat like a credit card to scrape the bulk of it off, then some rubbing alchohol to get the traces off. the purer alchohol the better, though 70 % isopropyl availiable at cvs or somthing other store will do fine. do you have some as3?
q149
q149
Japan
yeah i do, i plan to put it in place of the thermal pad on my northbridge, and in place of the thermal pad on my hsf i was temperarily using for a day....... thx
