Thermal Probe Question
customrig
Wethersfield, CT
I am thinking of buying a thermal probe with an LCD display and I have been hearing from people not to put it directly on the cpu in between a waterblock/heatsink but to put it somewhere else. Is this true and if it is where would I put it and would it give me accurate temps?
nikhsub1
Unoriginal Macho Moderator
Los Angeles
Obviously you can't put it between the CPU DIE and the block. To get a semi accurate Core temp you want the sensor to touch the SIDE of the core, you can tape it to the cpu so that it just touches the edge.
JFettig
Hey! I showered! Senior
MN
i took an old digital thermometer thats super acurate and goes to the tenth of a degree... and i desoldierd the probe and put it on 16in wires..put a pin header on the board so i can take it off and cut a hole in an old bay cover....
nikhsub1
Los Angeles
maskedgeek said:
does taping it to the bottom work??
But then you are getting temps like all socket probes in the mobo, from UNDER the CORE, does not a lot of good.
JFettig
MN
iv seen people do it for some reason, and i think its better cuz there isnt a big air gap....
