- Thread Starter
- #41
Thanks for the info on the cables... I was able to use the one I had without issues by going under the motherboard, I wasn't sure if I would have the right length but it all worked out for GPU so I only needed the motherboard 24pin which I got from LINKUP and its all working nicely.The extensions I mentioned some time ago just arrived. AsiaHorse brand isn't very popular, but they are available on every Amazon and are pretty good quality (I have white ones on another PC). I don't know if you think about a graphics card or the full set. The 12VHPWR cables are almost only black or white. I have the AsiaHorse working with my RTX4080 for some long months without issues.
I don't think you have to worry about anything. Spikes are normal, even up to 80°C+, as the OS picks single cores for background tasks, and even if you think it does nothing, then it actually does something that loads these cores up to 100% for a short time. Check Windows task manager and you will see how many things run at the same time.
Yeah the temps were off just the first day... now its all within 25c avg while doing what I mentioned above and only spikes up with games or heavier apps.
