So the day finally arrives after my long 5 day wait. My Ultima 90 was delivered
Installation was pretty much a pain. I pretty much had to unplug everything to take the mobo out and install the backplate. I have to admit... I fudged up and installed the brackets the wrong way so the HS was facing up... the wrong direction. I even told myself not to do that when I Was reading the online instructions a few days ago. Luckily, I managed to swap the brackets in the right direction without having to take the mobo out again. Haha! Lucky, Lucky. Anyways, here it is mounted with a Scythe Flex F model:
The HS base was very flat. As far as I could tell it was near perfect. The finish was semi-mirror like. It had a nice haze to it and there were almost microscopic finish lines. The "nail test" hardly revealed any ridges nor did it make sound... and my nails are a bit long right now. I still have a Nexus 92mm fan to add to the other side. I am going to do that tomorrow when I get my Zalman mfc2 fan/temp controller and attempt 3.6 ghz.
TR Ultima 90
Current Stats:
e6750 @ 3.06ghz:
IDLE: 25C
LOAD: 43C (orthos @ 10 mins)
e6750 @ 2.66ghz:
IDLE: 22C
LOAD: 40C
Stock Intel HSF:
e6750 @ 3.06ghz
IDLE: 32C
LOAD: 58C
e6750 @ 2.66ghz
IDLE:28C
LOAD: 56C
As one would determine from those numbers; I am VERY pleased!!! I consider these numbers to be a HUGE difference and I am sure I will have no problem getting up to my goal of 3.6ghz.
I made a mistake when I was making the screenshots while idleing. I didnt realize it at the time but when using MWsnap to take screens the cpu would spike taking the temps with it and I didnt get accurate readings. My mistake. I did remeber what they were however
I will post more pics later as well as more data. I will be able to give ambient temps tomorrow when my Zalman mfc2 arrives. I will also install the Nexus 92mm as a pull to see what kind of temp difference it will really make. My prediction is that it wont make much of a difference but we shall see.
TR Ultima 90
Current Stats:
e6750 @ 3.06ghz:
IDLE: 25C
e6750 @ 2.66ghz:
IDLE: 22C
LOAD: 40C
Stock Intel HSF:
e6750 @ 3.06ghz
IDLE: 32C
LOAD: 58C
e6750 @ 2.66ghz
IDLE:28C
LOAD: 56C
