Hey guys:
Did a cool build with the core p5 recently, figured it would be a waste if I didn't show it to some awesome people like you guys.
The case itself contains no radiators, nor pumps, they are placed in a separate external radiators+pump unit which I've designed and made using acrylic.
The distribution block is also my design and I got someone to custom made it for me.
Specs:
Cpu: i7 6700
GPU: Innon 3d 2080ti oc
RAM: 32G Corsair Vengeance DDR4 2666mhz
MB: MSI Z170a m7
PSU: XFX 1000w platinum
Case: Thermaltake core p5 white tempered glass edition.
Cooling:
Water blocks: Bykski CPU + GPU block.
Pumps: EK dual D5
Radiators: 4x 200*200mm fridge radiators
Fans: 4x Noctua 200mm Fans
Tubes: soft + rigid.
Some shots of work in progress:
After some heavy OC...
You can probably still find me on the Time Spy Graphic score x1 leaderboard
Might still end up modifying the external rad since the design is kinda flawed (extremely hard to assemble & disassemble).
New design:
So...thats basically it, hope you guys like it
Specs:
Cpu: i7 6700
MB: MSI Z170a m7
Cooling:
Pumps: EK dual D5
New design:
