I am helping someone put a system together with a Thermaltake 5000 case and an Asus P4S533 motherboard.
The Asus header uses a 9 pin array as follows
5V-2.....Data2-.....Data2+.....GND.....OC1#
5V-3.....Data3-.....Data3+.....GND
The ThermalTake case has 5 individual pin connectors labeled as
VCC1
VCC2
DATA-1
DATA-2
DATA+1
DATA+2
GND1
GND2
SHEILD
I connected the pins as follows
VCC1 ......5V-2
Data-1.....Data2-
Data+1....Data2+
GND1.......GND on top row
SHIELD....OC1#
VCC2.......5V-3
Data-2.....Data3-
Data+2....Data4+
GND2.......GND on bottom row
When I boot, IDE secondary does not reconize an devices connected to it (ie DVD played). Remove the pins and everything is fine.
What order should these pins be connected???
VCC1
VCC2
DATA-1
DATA-2
DATA+1
DATA+2
GND1
GND2
SHEILD
VCC1 ......5V-2
Data-1.....Data2-
Data+1....Data2+
SHIELD....OC1#
VCC2.......5V-3
Data-2.....Data3-
Data+2....Data4+
