- Jan 31, 2024
- Gulf Breeze, FL
Soon to be home of the 7950X and the 7900 XT. I have everything on hand but the radiator. Going to be some short runs of copper line for sure.
I removed the 140mm fans from the top and moved them to the back of the case. The 120mm fans now on the top will be the only ARGB in this case...a soft white light from above. Both sets are intake...the radiator fans will be the exhaust. As the three exhaust fans on the radiator will essentially be the only visible fans in the build I will use the Noctua's I have on hand...should tie in well with this color scheme.
