Thermaltake Volcano 7+
gogadgetman
Derby England
I require some help in finding where to buy a new fan for my Volcano 7+. Been on Thermaltake's web-site no luck. Model number TT-7025A dimensions 70x70x23mm
larva
Inactive Moderator
You could always fit one of the TMD 70mm fans to it, there aren't many choices in 70mm sizes. That was one thing I didn't care for about the 7+, the fan is a goofy size and it is annoyingly loud. I've gone to a heatsink that uses standard 80mm fans and I like both the noise/performance ratio and the choice of fans quite a bit.
gogadgetman
gogadgetman
Derby England
Thanks for your help and suggestions. Had Volcano about 5 months, fan just burnt out. Only got Volcano because it was so good for overclocking! and recommended by most of the Forums!
Robin Hood
Nottingham
There has been a post in the last couple of days were someone got a 80-120mm adapter to fit the 7+ and then used a regular 80mm fan - could be the cheapest option.
Edit - See the second post on this link
