- Jul 25, 2001
- Rovaniemi, Finland
I just read this article (http://www.swiftnets.com/cpu_temp_testing.htm). Now my MSI K7T Turbo has a thermistor which is soft bending kinda (like those orange flat cables you might see on HDDs) and I even nodded some thermal goo on top of it so it makes perfect contact with the CPU base. How accurate can I consider it to be?
How about lapping the sink base? How much difference does it make?
Im also thinking changing my PSU fan to more silent and low powered. Old one is 0.24A with sleeve bearing... Will the power overheat? Now that depends on power consumption but how much? btw. Its 300W AMD cert.
Now some smart answers, thanks.
