I think so, it falls back to 800mhz at idle..Isn't that the goal to use higher clock speeds only when needed?I doubt very much that chip is overclocked. 2nd pic on the left shows Hardware monitor and below shows CPU frequency @ 3.4Ghz.
Download and install CpuZ from here . Open the main tab (Cpuz) and it will show current cpu speed.
Most likely it's the turbo speed when under load.
Temps when using AIDA64 stress test (51c max) and CpuZ show 4008mhz..looks overclocked to me. Just don't see any need to run max speeds at idle..I been out of OCingThen it's not overclocked. It's running @ normal clock speeds, then enables turbo on it's own when needed. Overclocking is when you set the clock speeds in the bios manually for it to run oc'ed 24/7. You can also enable c-states and it will drop clock speeds when idle, but ramps up to overclocked settings when needed.
Your chip is running @ it's default settings.
My chip (sig) is running 4.7Ghz all the time. I set the clock speeds in bios and disabled the c-states (power saving) features for it to run @ my oc'ed settings constantly.
Turbo goes to 3.8Ghz on 4670k... he's overclocking.
This is a 4670K overclocking is enabled on this chip.
