So last week I overheated my cpu while gaming. Being the dumb dumb I am I let this happen several times. It was always a bsod followed by a reboot with a bios screen telling me as such. Since then I've had intermittently had BSOD referencing AMDauth. (Not home can provide dump file later). This mostly occurred after closing a gaming/streaming session. But sometimes during.
This far I've:
- Updated chipset drives and bios
- Ran P95 for 13 hours no errors, but still BSOD.
- Have tried PBO disabled and enabled. Currently on stock bios settings aside from manually setting ram clock speed (3600 which is not OC, for some reason it automatically set to 2133mhz)
-It has not overheated since. Have had the case side off with a fan blowing in.
- Windows memtest negative
- Ran sfc - corrupted files repaired. Still bsod.
Plan:
- Will do p95 for 24 hours
Mobo is asus tuf gaming x570 with wifi. 64gig ddr4 ram at 3600. Gtx4080ti
Assuming the memtest and p95 are negative for 24 hours. Can it still be the cpu with this amdauth error? I mean it all started after the overheat. Not sure why it would crash gaming but not with p95. Also considering some voltage issuses? I remember when I first built it I believe I had to do something with the voltage but I don't remember.
Any more testing to rule out the cpu? I'd like to try to avoid spending 300 bucks to find out it's not the cpu.
That being said. If needed, replace with same cpu? 5800x3d? Something else? Cooling is being upgraded to an aio from air.
Thanks.
DMP file debug:
docs.google.com
MODULE_NAME: AuthenticAMD
IMAGE_NAME: AuthenticAMD.sys
STACK_COMMAND: .cxr; .ecxr ; kb
FAILURE_BUCKET_ID: 0x124_0_AuthenticAMD_PROCESSOR_CACHE_IMAGE_AuthenticAMD.sys
OS_VERSION: 10.0.19041.1
BUILDLAB_STR: vb_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {d6c4d869-cd29-1e48-0267-5766712959d2}
This far I've:
Plan:
Thanks.
DMP file debug:
Debug
WHEA_UNCORRECTABLE_ERROR (124) A fatal hardware error has occurred. Parameter 1 identifies the type of error source that reported the error. Parameter 2 holds the address of the nt!_WHEA_ERROR_RECORD structure that describes the error condition. Try !errrec Address of the nt!_WHEA_ERROR_RECORD st...
OSNAME: Windows 10
