Do you think a strong water cooling system could keep that peltier from getting too hot? I know my alpa pep66t is good but water beats air does it not :Þ
Ok I have the INWIN Q500 case. Not to much room up top for the radiator. I could put one of the giant versions on the outside but I am trying to keep it neat. Now I have seen the Danger Den cooling cube: www.dangerden.com
Not as big as some of the giant raditors but its compact and will fit just neatly up top of the powersupply. But will that cube with a 120mm fan on it handle say a 118watt TEC ? I have been coresponding with http://www.leufkentechnologies.com and they said with a 118watt TEC go with thier giant raditor but its size makes it a hard fit. I do not want to fall into the "too weak of TEC for cpu used" trap or the insufficent cooling for TEC/CPU combo. Any suggestions for a powerfull yet compact radiator?
