Thinking of going with an Alpha...
The Poopster
I'm thinking of scrapping my GORB and goin with an Alpha P3125. The only thing stopping me is its size. I have an Abit Vt6x4, if I get one will it fit well or is it going to block any of my RAM DIMMS? I'm not really willing to give any of them up.
The Poopster
someone had posted this before. I am new but trying to lend a hand. Check out this link http://www.thetechzone.com. You need to click on the show all reviews, then find the review with the title "Vos32 vs. P3125". I just purchased two Global Win VOS32s for my systems. You might want to check them out, they have made it so you won't lose RAMM spots. However, I have not recieved mine so I don't know how true that is.
I hadn't even considered the globalwin, but it looks like its a good choice. I want to place an order for one today but I need to know what kind of power connecters the fans utilize. Are they 3 pin or 4? And should I order any wiring to go with them? (Like a 3 pin y to 4pin adapter maybe?)
Thanks for the advice,
El Poopster con Queso
