- Jan 4, 2002
- Raleigh, NC--NCSU
My dad is currently toying with the idea of replacing 2 of the drafting machines at his office with 2 duallies.
He's an architect, and one of his new programs is apparently designed to take advantage of dual CPU's.
I've never messed with SMP before, so I put forth the following for your expert opinion. I tried to do a little research beforehand, hopefully it's ok.
(We would be replacing everything but the monitors and the hard drives, which is why they aren't in the list.)
Motherboard: MSI K7-D Master-L
CPUs: XP1700+ TBredB's
Video: Gainward Ti4200 128MB 3.6ns
RAM: 1GB of PC2700 Corsair (2x512MB)
Case: Chieftec full tower aluminum
My dad likes the water cooling that he currently has on his office machine, and thinks that he'd like to put H2O on these computers too---hopefully it'll all fit.
Waterblocks
-Tek TC-4's
Radiator: D-Tek heatercore/shroud combo
Tubing: Clearflex60
Pump: ViaAqua1300
Fan: 120mm Sunon
Misc. purple ice and y-adapters.
If we don't go H2O, we'll use:
SLK-800's with the 84cfm 80mm Sunon hsf, as reviewed here.
The TBird1.4 and XP1600+ that these duallies would be replacing will replace 2 other machines in his office, and then one of those will replace yet another, for a total of 5 machines upgraded for under $2k.
I totaled everything up and the difference between H2O and air is only $197, which is negligible, so we'll probably go H2O.
If anything on this list won't fit (ie: waterblocks on mobo, hsf's on mobo, etc) please tell me.
Any input/thoughts/comments would be appreciated.
edit: I forgot to mention this, I know it's going to come up---Yes, the idea is to overclock these.
Waterblocks
Tubing: Clearflex60
Pump: ViaAqua1300
Fan: 120mm Sunon
