It all started a month ago when I turned on my PC and POOF sparks flew out of the power supply. I went down to Best Buy and bought a 300W Antech and put it in my case. When I turned on the power, it wouldn't boot. The hard drive would spin up and the CD-ROM light would come on but the floopy wouldn't seek and I couldn't even get into the BIOS although the fans worked.
So, I took it to Best Buy and had them diagnose it. A bad motherboard and/or CPU was all they could GUESS ($60 for a guess..grrrr). I tested my CPU and it was OK so I ordered a new MB. Well when I installed it, the same IDENTICAL symptoms occured. Not boot, but the hard drive would spin up, the fans would turn, etc.
I thought that I must have just gotten a bad MB, but since the CPU was a little old I thought I might as well upgrade the whole thing. So, I buy a new motherboard (the new Soltek) a new CPU (AMD 1600+ retail), new memory (PC2700 Kingmax) and even a new case (just on the oddball chance that the wires were bad). I hook everything up and guess what? The exact same thing occurs. No boot, just my hard drive spinning up, the CD-ROM light coming on and the fans turning. The floppy still doesn't seek and this time the mouse sometimes does and sometimes does not work.
I have replaced EVERYTHING that could prevent the system from booting at least to the point whe I can get into the BIOS and have tried both AGP and PCI based video cards but nothing helps.
Does anyone have a clue as to what it might be? The only thing I thought is maybe I have a bad power unit and the 12V is working but not the 5.
Please help! I've spent so much time and money on this thing that I'm about to go crazy.
