- Jan 21, 2001
Need to COOL my tbird just a little more, and i`m out of cash.
But i have one good idea.
At the moment i posses:
a] 2 40Watt tec
b] 1 Alpha pal6035 with delta HP fan
c] enough space for watercooling
d] some other resources.
Im planning to do the following.
build waterblok out of the alpha heatsink. [soldering some small slices of metal to the sides.
[the clip remains a problem, remove it, and use a different clamping method... [not yet solved]
On the core put one very thick colplate. Next the plate should be linke 3Cm high, so that i have enough space for the following.
Put a larger thin coldplate on the original one, and place 2 40W tecs on that, finally another small coldplate with above of this little tower est. height so far 4Cm] The modded alpha->waterblock.
Now this should be pretty much low budget. and rather powerfull.
Has anyone thought of this before and tested it? or other quality comments about this little project?
a] 2 40Watt tec
