- Apr 21, 2001
- OH-Heartland of the USA
The picture is of a cold air chute I constructed out of plexiglass(yea I know, too much time on my hands). The curve at the top goes against the HSF. Anyway, the idea was to port cool air from the bottom of the case directly into the intake of the HS fan. I also installed a small fan to help force the air up the chute. Well, I didn't notice any change in temps, but I think I know why. Even though the fan in the middle(it's the small one that comes with the Taisol HSF) is creating a pressure on the intake of the HS fan, the HS fan cannot push any more air than it is designed to and this condition may even decrease the efficiency of the HS fan.
Now, do you think it COULD work if I reversed the airflow of both fans?? Would this allow more air to flow through the chute by PULLING the air through the HS fins??
The HSF is a Taisol aluminum and it has a 26cfm fan on it from a FOP32-1.
I think I will try reversing them and see what happens.
Thanks for your time and comments.
"I don't get frustrated, I just try something else!!"
