you should upgrade the ram to get the 166 fsb, deathstar u were wrong My ram let me up the fsb 10 mhz and i can still go higher but im tryin to make sure its stable
No, there is absolutely no multiplier menu in the bios on this board. Even when you put it to auto. I'll put the fsb jumper to 166, and it will boot as 100. I think the mobo might sense what type of ram it is and limit the fsb to the correct freqs.
are you sure you have the jumper settings correct? That happened to me with my ga7 vax and it took me a minute to realize I'm stupid I'm looking at my manual right now and the two settings (166 and 100 fsb) are alike except oposite.. wait am I making sense? The colors confuse you I know so make sure that the one on the right i pushed up and the one on the left is pushed down. Hope this helps and to fix you mult just use the other jumper located right near the cpu!
