Okay, first you get a 44 gallon oil drum filled with crushed ice, then you tip a jug of vermouth in, shake and then drain the ice dry. Now throw in the rest of the ingredients, shake well, or STIR if you are particular, garnish with a cherry and a tres chic little cocktail umbrella and serve. . . . . .
Hmmm I might have been confusing that with a martini recipe.
Okay, best way to do it.
1) get a friend to help. Any friend that can read, get him to double check your interpretation of the engrish in the manuals and help spot obvious booboos.
2) Start simple, just start with motherboard, CPU, properly seated cooler, RAM, and graphics card in your case. Install those, make sure everything is seated correctly, check with a small mirror held alongside the slots that everything is sitting down right if you can't see. A flashlight is useful too.
3) Plug it in and power it on with just those components installed, monitor attached. If you get a boot screen you are doing good. Turn off. Pull out the plug. If you don't get a boot screen turn off pull out the plug, reseat everything, check the fan connections, dishcharge the CMOS ram as instructed in the motherboard manual. Try again.
4) You can basically just add everything once you have the basics working, however read install instructions for all your hardware carefully, some hardware prefers to be installed after windows is installed, and likes to have it's drivers installed first before you install the hardware. Any problems, just take out stuff one piece at a time until it works or you are back at 3)
Points to remember:
*Discharge any static frequently or use a wrist strap.
*don't panic
*dont do anything inside the machine while it is plugged in, on 486s you could do this, not on modern machines.
*Get a friend to help, but don't turn it into a party, no beer until you have the case screwed shut!
*Go slow, double check everything, get your friend to check too.
Dunno if that was too basic, thought it might be useful, good luck,
Road Warrior
