- Jul 17, 2003
My machine is locking up a lot lately. I have an AMD 399 chipset with a 1st gen Threadripper 1900. I'm using this RAM
(Crucial Ballistix Sport AT)
www.newegg.com
on this board
(ASRock X399 Taichi)
www.newegg.com
this cooler with dual fans
(Noctua NH-U14S)
www.newegg.com
I also have a 512 GB Samsung 970 NVMe and a 1TB HP 950 NVMe installed and a few optical drives.
I also have an EVGA 3080Ti and an EVGA 3060.
The machine will lock up tight at various times. Note that I fold with the machine 24/7.
I know that the RAM is not fully compatible. The first issue showed when I bought a matching kit of RAM for 8 x 8GB = 64GB RAM. The Board just didn't like it. So I put one 4 x 8 kit in my drawer for future use and have been running the other 4 x 8 GB kit since 2019.
Steps taken:
I recently moved this system from one case to another. I'm using a different power supply so that isn't it.
While I did not reseat the HSF on the CPU, the cooling configuration is completely different. I'll re-do the HSF. Could that be it?
I'm thinking of getting AMD compatible RAM while it's reasonably cheap yet. For bragging rights only I'd like to get 8 x 8GB = 64 which is half of the 128 that this board maxes out at.
Crucial Ballistix Sport AT 3200 MHz DDR4 DRAM Desktop Gaming Memory Kit 16GB (8GBx2) CL16 BLS2K8G4D32AESTK - Newegg.com
Buy Crucial Ballistix Sport AT 3200 MHz DDR4 DRAM Desktop Gaming Memory Kit 16GB (8GBx2) CL16 BLS2K8G4D32AESTK with fast shipping and top-rated customer service. Once you know, you Newegg!
Open Box: ASRock X399 Taichi sTR4 ATX AMD Motherboard - Newegg.com
Buy Open Box: ASRock X399 Taichi sTR4 AMD X399 SATA 6Gb/s ATX AMD Motherboard with fast shipping and top-rated customer service. Once you know, you Newegg!
(Noctua NH-U14S)
Noctua NH-U14S TR4-SP3, Premium-grade CPU Cooler for AMD sTRX4/TR4/SP3 (140mm, Brown) - Newegg.com
Buy Noctua NH-U14S TR4-SP3, Premium-grade CPU Cooler for AMD sTRX4/TR4/SP3 (140mm, Brown) with fast shipping and top-rated customer service. Once you know, you Newegg!
Steps taken:
