Thunderbird Coolers
Goin' AMD
Going to build an AMD system with Abit KG7-Raid. Of course I'm gonna push it to the limit! What are the best coolers for the Overclocked AMD socket A?
Thanks everyone! Looking very close at the new Millenium Glaciator.
Anybody have one yet? Let's here about it........
I can suggest the millenium glaciator. It made a world of difference on my tbird and the setup is very quiet. It's also reasonably price in comparison.
I have the thermoengine with the stock fan and I am pleased with it , at 1366 my temps are 40c and 47-48 useing cpu burn which I dont think is really to bad so I would recommend it to anyone
wildone
I am using a FOP 32-1 on my T-Bird 1.4 Ghz. It isn't great, but it is cheap and quiet and works well if you are low on budget. But after reading other reviews I would suggest the Glaciator from what I've heard.
If you're sticking with air cooling, I would definitely recommend the ThermoEngine with the Delta Fan, the stock one is pretty small. Be sure to remove that damn pad off of the bottom and replace it with some A.S. II. :)
Goin' AMD (Jul 04, 2001 04:35 p.m.):
Thanks everyone, anybody got the new Millenium Glaciator yet? I'm looking very close at this one!
