Time for a new PSU?
DamienKC
Hi, I'm just needing some input from all of you :)
I'm currently using the Turbolink 420W psu that came with my case, and here are my average voltages according to Hardware Doctor
Vcore - 1.49 (it's set to 1.55 in bios...wtf)
DDR - 2.73
+3.3 rail - 3.31
+5 rail - 5.09
+12 rail - 11.86
IMO the 5 and 12 and vcore are pretty bad, but are those bad enough to NEED a new psu?
Thanks!l
SunTzu69
Canada
Well,
It seems you're in it to overclock. If you are, a high quality PSU can only help. :santa2:
I for one am getting a Sparkle/Fortron 530W and no other. Antec would be great too. It's really the foundation (along with the mobo) for a good overclock.
DamienKC
DamienKC
Yeah, my first choice was the Fortron 530W, cheap, and has good reviews.
Vio1
Toronto Canada
you dont need a new PSU. Your rails are close enough... not even in a dangerous level. if you start getting 3v on a 3.3v or 4.7v on a 5v or 11v on 12v rail then Id think of getting a new psu. otherwise your in the clear.
Turd Furguson
Ashland, KY
Please check your voltages on all those lines with a Digital Multimeter to get accurate results. Software could be not reporting properly.
Nebulous
Señor Senior, Senior
The Empire State
I cuncur with Turd. Don't rely on software to read the voltages. They read off the same sensors as the bios and could be misleading. To get accurate readings do what Turd suggested.
Mr.Radar
Turbo Link PSUs tend to be on the lower end of the quality scale. I'd reccomend replacing it. If you can afford it definately go with the Sparkle 530 (exactly the same as the Fortron 530 except it's sold for a lower price), however the Sparkle 400 should also be good, or any of the Antec TruePowers (at or above 380 watts).
Vio1
Toronto Canada
I just understand you people.... his rails are normal... maybe the bios is reading it a bit wrong, but there is no reason to get a new psu! Unless of course you are having problems.
