Hello, it's that time again. Want to spend around $800 no peripherals, and would prefer to stay under $900 with windows. I want to use this to game at 1080P 60fps on ultra settings. I have a base build and then two variants, each allocating differend amounts of money into CPU, GPU and RAM. It's essentially a question between an i5 6500 & 6GB 1060, and an i5 6600K & 3GB 1060. I'd OC a bit down the road with the 6600K. I am open to suggestions for any of the other parts in the base build, like if the PSU would be good to OC on, as well as the RAM I chose. I do have kind of specific case needs/wants: black, window, no LEDs, vented front bezel over 120mm intake fan, 120mm rear fan. Also I prefer GPUs that have nice coolers, not the plastic-y ones. In the past I've had tons of issues with stock CPU coolers so I might get the CM 212 evo regardless of which CPU I get. I do have a ~230gb sandisk SSD that I will be recycling from my current build.
Base Build
PCPartPicker part list / Price breakdown by merchant
Motherboard: Gigabyte GA-Z170-HD3 ATX LGA1151 Motherboard ($99.99 @ NCIX US)
Storage: Seagate BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive ($48.19 @ NCIX US)
Case: Cooler Master MasterBox 5 (Black) ATX Mid Tower Case ($62.99 @ SuperBiiz)
Power Supply: SeaSonic G 550W 80+ Gold Certified Semi-Modular ATX Power Supply ($59.99 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM 64-bit ($99.98 @ OutletPC)
Total: $371.14
Build A: 6600K, 3GB 1060, 8GB RAM
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor ($229.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($26.88 @ OutletPC)
Memory: G.Skill Ripjaws V Series 8GB (2 x 4GB) DDR4-2400 Memory ($48.99 @ Newegg)
Video Card: Gigabyte GeForce GTX 1060 3GB 3GB Windforce OC Video Card ($199.99 @ Jet)
Total ($505.85 + base): $865.59
Build B: 6500, 6GB 1060, 8GB RAM
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor ($189.99 @ SuperBiiz)
Video Card: Gigabyte GeForce GTX 1060 6GB 6GB WINDFORCE OC 6G Video Card ($249.99 @ Jet)
Total ($488.97 + base): $860.11
I toyed with a "Build C" that had the 6500, 3GB 1060 and 16GB RAM but I think that'd be a bad idea since RAM is so cheap to add later if needed. Anyway, appreciate any input. Thanks!
Base Build
Total: $371.14
