Time to change the monitor after my new rig (5820K+r9 390)
mt_196
Rome, IT
Hi guys, I need some help.
I'm buying a new rig:
MSI X99A Sli Krait
i7-5820K
Prolimatech Genesis
16Gb DDR4 Corsair Vengeance LPX 2400Mhz CL14
Sapphire R9 390 8Gb
Samsung 850PRO 256Gb
Samsung 850EVO 1Tb
I have an old Samsung XL2370HD TN monitor 5ms response time and I think that it's more or less the time to change it.
I don't know really much about monitors, but I know that IPS panels have better color and viewing angles, so I'll stick with one of them even if they don't have 1 or 2ms. I think the sweet spot is something aroung 4-5ms and IPS.
I'll like to play with it, but also watch movies and Netflix.
Do you think I have to take a 21:9 FullHD monitor or a QHD one?
Thanks
M
mt_196
Rome, IT
I'll be sitting at around 40cm from my monitor, how many inches do you thin is the best?
Witchdoctor
I personally like 27" on a standard desk like yours
2560x1440 is a great median , not to difficult to push and outstanding visuals
I believe it to be the sweet spot, they have a toe of options as well, anything from cheap Korean models to High end 144 hz 3d models and everything in between
M
mt_196
Rome, IT
Ok, thanks. Can you give me some examples of monitors that have the best value for their price?
27" IPS not more than 4-5ms 60hz
M
mt_196
Rome, IT
Ok, understood. However I think that more than 1440p 60Hz is wasted, I mean my 390 can't max a 144Mhz 1440p, so maybe is better to take a 60hz that will be anyway a huge step from a 23" TN panel, am I right?
M
mt_196
Rome, IT
I'll really like to stay 1440p.
I found this two models:
the Dell U2717 that is coming out soon
the Acer H277HU that is 5ms 144Mhz
M
mt_196
Rome, IT
I saw that I need to push tthe budget up to around 450€
I heard of the stunning color quality of Dells, only concern is the 8ms response time
