- Jul 18, 2001
Update To CD v9.5
Version 9.5 Has the Following Updates Or Additions:
Refer To Menu Images For Updated List Of Bios's For Motherboards
Added ICFX3200 T2R/G Bios Menu
Added R6TDC18 & R6TDC22 ICFX3200 T2R/G Bios's
Updated Hitachi Feature Tool To 2.04
Fixed Problem With Hitachi Drive Fitness Tool
Updated MemTest To v1.70
Updated Virus Signature File For F-Prot
Please see menu's for bios versions.
Tutorials on ISO extraction as well as burning the ISO using Nero or Nero Express are located in posts 3, 4, and 5 right below this post.
(The tutorials were written using CD2 as the base but will work equally as well with CD v8.5, Just replace CD2 with CD v9.5)
No Trojans Here:
I have had several PM's or posts regarding my CD containing a trojan, There are no trojan's on my CD.
The problem is most likely encountered when using Avast as it gives a false positive.
KillCMOS acts like a virus in that it wipes out the CMOS, Not destroying it but clearing it like no other method does.
So rest assured I would not place a trojan in my CD.
Please look at the menu images for the content of the CD, The images are always updated when a change is made to the CD or a new version is released.
Here is some images of my version of the Bios Flashing CD, But I also added some extra utilities to boot.
You must use the arrow keys for navigation around the menus.
Once you select what you want to execute and if there is a mouse driver in the program you select you will be able to use the mouse to navigate in the program.
Feedback is always welcome and I value any suggestions for this product.
DISCLAIMER
TMODS CD v9.5 IS PROVIDED "AS IS" WITHOUT ANY EXPRESSED OR
IMPLIED WARRANTY OF ANY KIND INCLUDING WARRANTIES OF MERCHANTABILITY,
NONINFRINGEMENT OF INTELLECTUAL PROPERTY, OR FITNESS FOR ANY
PARTICULAR PURPOSE. IN NO EVENT SHALL OCFORUMS.COM OR MYSELF OR ITS SUPPLIERS BE LIABLE
FOR ANY DAMAGES WHATSOEVER (INCLUDING, WITHOUT LIMITATION, DAMAGES
FOR LOSS OF PROFITS, BUSINESS INTERRUPTION, LOSS OF INFORMATION)
ARISING OUT OF THE USE OF OR INABILITY TO USE TMODS CD v9.5,
EVEN IF OCFORUMS.COM OR MYSELF HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES.
Main Menu
Infinity Series Menu
LanParty Series Menu
NF2 Ultra Infinity Menu
NF2 LanParty "B" Menu
NF3 LanParty UT 250Gb Menu
NF3 LanParty UT Ultra-D Menu
NF4 LanParty Menu
NF4 LanParty Window (Second Menu)
NF4 Infinity Menu
Some Explanation's of the CD.
The four original bios's at the top of the NF2 Ultra Infinity Windows and the NF2 LanParty "B" Windows have the latest Silicon Image 5.0.52 SATA Bios in them.
The Hard Drive Diagnostic Utility?s will work on any system that has a Hard Drive from one of the manufacturers listed in the menu.
MemTest86+ is the latest version available when I created this and it will work on any system that will boot from a CD and is compatible with MemTest86+.
Killdisk is a program that writes 0?s to the Hard Drive. This utility comes in handy when you decide to perform a clean install of any OS. You just select it from the menu and then select your hard drive from the list and execute it. You will then have a hard drive that is as clean as when it came out of the box.
KillCMOS is a small utility that clears the CMOS of any system, It will reset the bios password and any other settings will all be returned to bios default.
AIDA16 will give you information pertaining to your system hardware and bios.
Prime v24.14 needs no introduction, You know what it does.
Flash From Hard Drive gives you access to the C: Drive so you can flash from it in case you have a a different file you want to try but don't want to use a floppy boot disk to gain access.
Boot To Hard Drive is just that, Boot?s to the C:\ Drive.
Reboot is just that, Reboots the system.
Tmods CD v9.5
This Link Is For The Download Of Tmods CD v9.5 (Full ISO)
This Link Is For The Download Of Tmods CD v9.5 (Full ISO) (Mirror)
This Link Is For The Download Of Tmods CD v9.5 (Full ISO) (Mirror)(Fast Server)
MD5 Hash for Tmods CD 9.5, Place in a file and name the file checksums.md5 and run your favorite MD5 checker to check that the download was not corrupted or changed.
82D7FCE0BF5AE4646E31CA724DDBB379 *Tmods CD v9.5.iso
BETA:
Tmods CD2.iso Extraction Tutorial (Flash Based).
Tmod
No Trojans Here:
DISCLAIMER
Main Menu
NF4 LanParty Menu
NF4 Infinity Menu
Tmods CD v9.5
BETA:
Tmod
