All too often I see people advising others that AMD cpu's running at temps 60 are in the danger zone for damage.
If one browses through the builders guide, how they suggest cooling be added to AMD systems50 c's is great sport.. 60 is normal, first critical at 70.
Anything lower than 60 would usually force towards extra costs, that woud otherwise make an Intel system at same price, but cooler.
I doubt anyone with standard fan and standard case had temps as low as 50 on palomino systems, and it is still designed to be used in standard environments.
So to all the newcomers, I'd suggest not to react unless it hits 70, and request from the rest, that if you give an advice for the sport of going as low as possible, then state so.... not all people are "coolers for sports" people.
Cheers, Flixotide
Cheers, Flixotide
