So, I've upgraded my i7-4790k for a new i7-8700k and so far it seems to be a good sample. Below is where I'm at with my OC progress along with the associated voltage requirements and resulting temps. I'm running a custom loop with the following components. I'm happy with the overclock but wondering if I could squeeze more out to make it worth voiding my warranty. I'm averaging about a 6°C difference between cores. What do you say?
[oldtable]CPU Block|EKWB Supremacy EVO Full Copper
Radiator(s)|Swifttech 30mmx360mm
Pump/Res Combo|EKWB D5 Xres (set to 5-Max)
Fans|3x Yate Loon D12SH-12 120mm High Speed[/table]
Stress testing was done using AIDA64 Engineer CPU & FPU tests for 30 minutes. Here are my O.C. Notes.
[oldtable]CPU Mhz|Multi Setting|FSB Setting|vCore|LLC|AVX Offset|Max Package Temp|Max Core (Core#)|Min Core Temp (Core #)|Result
4.3Ghz/4.7Ghz(Stock)|43|100|1.152v|Auto|Auto|58°C|58°C(2&3)|56°C(1,4&5)|Pass
4.7Ghz|47|100|1.300v|1|0|75°C|74°C(2&3)|70°C(5)|Pass
4.9Ghz|49|100|1.300v|1|0|84°C|84°C(2)|78°C(1&5)|Pass
5.0Ghz|50|100|1.300v|1|0|85°C|85°C(2&3)|79°C(5)|Pass
5.1Ghz|51|100|1.300v|4|0|XX°C|XX°C()|XX°C()|Sys Hang
5.1Ghz|51|100|1.300v|1|0|75°C|XX°C()|XX°C()|Sys Hang
5.1Ghz|51|100|1.325v|1|0|89°C|89°C(2)|83°C(1)|Pass
5.2Ghz|52|100|1.325v|1|0|XX°C|XX°C()|XX°C()|Sys Hang
5.2Ghz|52|100|1.350v|1|-1|XX°C|XX°C()|XX°C()|Sys Hang
5.2Ghz|52|100|1.375v|1|-2|94°C|93°C(2)|86°C(1&5)|Test Stopped-Temps
5.2Ghz|52|100|1.365v|1|-1|93°C|93°C(2)|85°C(1)|Test Stopped-Temps
5.2Ghz|52|100|1.355v|1|-1|93°C|93°C(2)|85°C(1)|Test Stopped-Temps[/table]
EDIT:
Additional notes. I do run Handbrake frequently and at the 5.1Ghz setting I'm getting about an average of 80% utilization across all 12 threads and my max temps are about 84°C Package and 83° on core #2.
EDIT:
