ok heres my systems specs
Raidmax case with 4 80mm intakes in front, 2 in rear and one in sidepanel over cpu and a blowhole on top coming soon.
ABIT kx7-333r
1.4athlon t-bird w/V9
512 (2x256) pny pc2100
2-20GB WD hard drives
40GB wd Hard drive
DVD-rom
24x cd-burner
100MB zip drive
ok my problem is i have way way way to many molex connectors in my case.I was thinking of splicing all the fan wires together to illiminate some of them, but i don't know how safe it is or of any precautions i need to be aware of. I have like 4 molex "Y" splitters. I have most of the wires wrapped but it still loks really ugly having a bunch of big white connectors sticking out.
has anyone ever tried this? basically the only connectors i wanna see are the ones that plug directly into my devices.
also i want to make the wires as invisible as possible so i was thinking about lengthening some and running them along the borders of the case frame. will lengthening create any problems with things getting power?
i'll post a pic of my case later when i can find the disc they are on.
thanks,
Twump
ABIT kx7-333r
40GB wd Hard drive
DVD-rom
24x cd-burner
100MB zip drive
thanks,
Twump
