- Oct 9, 2003
- Tampere, Finland
Hi, I've been playing around with the idea about painting my aopen case. But I'm wondering if the shape of the model would be a hinderance. So here's a few linkies to pics of the case I found from the manufactors case...
The case - full frontal
The case - side wide open
I wan't to paint a case with the mirror finish , but I don't know what to do with the plastic front panel. It's easily the ugliest part of the case, but it has other benefits like two usb ports and mic and audio out.
So should I first get some other cheap maybe used case and try to paint that instead of this one. (I like this option)
Or should I go ahead and try to paint this case, and with all your help think a solution to the front panel problem?
