tooo hot ????????????????????
montecristo
can any of you give my some help?
MI cpu (1200- amd) gets too hot??????????
65c as standard
what is the standard for a 1200 amd cpu?
Depends alot on what heatsink your using, thats hot but it happens with a crappy heat sink, if your using an oem or generic heat sink id suggest a global win FOP32, it'll lower the temps a good bit from there. My Athlon 750 is running 900 and sits at 40C all the time, the 1200 will be a bit warmer but should still be under 50C with a FOP32. The FOP38 I have cools better but its EXTREMELY noisy...
THAT IS THE FOP38 IAM YUSING I YUST CHANG IT WIT THE STANDARD A BUT, STILL A GLOBALL BUT NOW THE TEM IS 71C
