Hi folks, long time lurker, first time poster.
My question's a little more complicated than the subject line. I want to build a clean, quiet, watercooled gaming machine, and I'm interested in keeping all components inside the case. I've been looking at the dimensions of various radiators and cases, and I've been trying to figure out how some of these parts can fit together, but I just don't have the resources to find out for sure what'll work. That's where the experts here come in.
I like the P180B (though I'll probably wait for the P182). Here are a few options I'm considering for it:
1 - A Thermochill PA120.2 at the top, and a PA120.1 in the back. I think they're too thick to fit, but I could always put the fans on the top of the case in a nice black shroud, or I could simply go with a thinner rad on top.
2 - A PA160 at the top and a PA120.1 in the back. This could be a much sweeter looking option as it would potentially allow me to connect the 2 rads together with just an elbow pipe and some short fittings, essentially turning them into a single L-shaped radiator. The 160 would require at least a 140mm fan though, as there'd really be no room for the 120mm shroud and fan.
3 - 2 PA160s on top.
All options require some case-cutting, but that's not an issue. I'm planning on putting some hot parts into this thing (overclocked C2D, 680i, 8800GTX) so I'd rather not hear anyone use the word overkill in this thread.
Also, I do not want to put a radiator in the front. I plan on putting 4 hard drives into the bottom drive cage and the pump in the upper cage's spot.
So... what do you think would fit?
