Recently built a new machine with a Sata enabled GIGABYTE Z170 motherboard. I have a Sata hooked up to a WD HDD with Windows
C) and all is well. I later hooked up a 2nd SATA cable (and power) to a Toshiba DT01ACA100 HDD but I can't see it in Bios OR windows (Even as unidentified in the computer management window).
There doesn't appear to be any drivers so it can't be drivers. The sata is fine as the other HDD works fine. Tried switching between two and it just doesn't see the Toshiba.
