- Oct 14, 2009
So I have a choice to make - My system specs are in my sig below:
Should I upgrade from the 4890 to a 5870
or
go for a water cooling set-up and TRY to go from 4.2ghz to 4.5ghz
with these parts:
Swiftech MCP355 with XSPC Top
Apogee XT
Danger Den brass fillport
Petra's PT biocide
XSPC RX240 Dual 120mm Radiator
PrimoChill PrimoFlex PRO LRT Tubing 3/8"ID 5/8" OD with 1/8" Wall - UV Red
Danger Den Delrin T-Fitting
Bitspower Chrome G1/4" Barb Fitting - 3/8" ID
Which would yield the most performance increase?
Games played:
Modern Warfare 2
Flight Simulator X
CS:S
similar games.. all maxed out and running 60-120fps (i think i may have just answered my own question)
or
with these parts:
Apogee XT
Petra's PT biocide
Games played:
Modern Warfare 2
Flight Simulator X
CS:S
