- Mar 7, 2008
Which RGB ram?
https://www.techpowerup.com/228831/...y-rgb-lighting-ddr4-with-trident-z-rgb-series
Ok, the G.Skill has been discussed already on this forum. I think it is the nicest looking and would probably be my choice, even if I was never a fan of the TridentZ fins. I do like the pastel colour effect, and that you can fade between two colours as well as animate the lighting.
https://www.techpowerup.com/229460/...r4-memory-with-remote-controlled-rgb-lighting
The Geil doesn't do it for me. The obvious wires are not a good start and the module styling is nothing to speak of either. The remote control is one of the ones you see all over the coloured lights on ebay.
https://www.techpowerup.com/229452/corsair-vengeance-rgb-series-memory-pictured
Corsair had a good try but I want to see more of the lighting. Maybe this is a good choice for a more discreet but still accented build?
https://www.techpowerup.com/229462/kingston-shows-off-hyperx-predator-led-ddr4-memory
And Kingston... they don't look much in photos, but in videos the lighting areas can be animated into patterns.
