- Dec 4, 2016
Hi everyone,
I will be building the tower 900 system. Two loops 1 for CPU and 1 for GPUS. The case in the rear has rad 4 on the right with 4 fans and rad 2 on the left with two fans with two rear mounted fans and 1 on the top. The front of the case has a fan in the middle on a pedestal and also the top. I am confused on which which way I need to setup these fans to get the most optimal cooling.. I have drawn some quick pics with MS Paint since I don't have Autocad on this pc. Please feel free to edit or please tell me which direction everything needs to face.
2nd Part: The cooling loop. The return will be the inlet at the top of the resi. So I am assuming the loops goes as follows: Out from pump, to CPU In, CPU out to Rad In, Rad out back to the inlet at the top of the reservoir. is this correct?
All help much appreciated!
