- Jan 4, 2001
- Northern VA
I just did the FOP32 Hack as mentioned on the Overclockers site. I must say, I am very happy I did it. A few comments though.
The hack is basically about removing the global win fan off the FOP38 hs/f, which anyone who has one knows is VERY loud. I was able to put up with it, but once I saw the hack I was interested. I have a pretty new Antec case fan, which was still in my old system which currenlty isn't being used due to lack of monitors. so I took it out (something I shoulda done a while ago) and began to look at how exactly it would fit on.
By the way, its pretty impossible to do this with the hsf on the cpu, so take it off. I would've like to not have too, its a pain to put on, and I am still paranoid about damaging my Tbird.
At first look, I thought "No way is this gonna fit on." The case fan was MUCH larger than the fop38 I had. But I took the fop38 off, and found the the metal clips that hold it on can bend out enough to fit the case fan on. Worked quite well infact. The key is to put on end of the metal clip in one of the fan's screw holes, then put the middle of the clip in the groove on the heatsink, then using needle nose pliers (makes things much easier) just pull the other end up to the fan, and there you go. Make sure you keep the fan centered and that its straight.
Once done, it seems to keep my chip jsut as cool as the fop38 did, perhaps even a bit cooler, as I was getting 48C on full load and no higher, which was about what I got before. Oh, and that was a Tbird 900 running at 1000.
As for noise levels...they are MUCH down. I recommend this to anyone with an fop38 and a spare case fan, or even go spend a few bucks on one, its worth it.
Oh, and while I was in there, I pulled the chip out and penciled in my L1 bridges, worked great and was free. (I found the pencil in my house, so I really don't think I spent money on it...anyway, I can take notes with the pencil, can't do that with a conductive pen!)
So I'm happy with my fan swap, and sicne I do audio recording (sometimes mic'ing instruments such as acoustic guitar and piano), that makes me feel better sound-wise.
Mike
P.S. About my temps, I wasn't happy at all with my 45C plus temps, I plan on upgrading my cooling system soon, but after reading the post about a Tbird functioning at 79C....I felt a little bit better! Still gonna get those temps down though.
P.P.S. While I mentionng all this, anyone who doesn't yet have the global win fop38 heatsink and fan...I don't reccomend them...there are superior units out there for just as much.
Mike
