Yes thats correct , i tried loads of things last night (up til 2 am) and still could not get it to run stable , even raised the fsb and dropped the multipier , still no good . It was cold last night so my temps were never a problem. I was plagued with blue screen if you prime stayed runningSo, just to get it straight, your CPU NB VID is set to +0.025 and that gives you a cpuNB voltage of 1.225v?
Then my guess is your board is giving out on you. With so many BE chips available board manufacturers have little need to emphasize clock speed in their design/construction model. Have you tested this by lowering the CPU and raising the clock? If you can raise the clock and everything is stable then it's the CPU hitting it's top-end but if it's unstable even at a lower CPU speed then it's most likely the board hitting it's top-end.
Of course, that's the simple theory. In reality, you will have only eliminated the CPU as the source of the problem.
The 445 and 450 are both "AMD safe" at 1.50 vCore. No specific information on your 425 but I can't imagine it being much different.just a quick update on this one guys , new psu and cooler installed and got it to 4.1 ghz stable running 39 degs during prime . Is the max recommended vcore 1.5v for this cpu , as im at 1.475 to get it stable for longer than 15 mins on p95 , wonder if 1.5 would give another 100mhz (if my ram will take the overclock) .
