I've read around this forum and around other places on the internet and believe that I have chosen the components for a workable build. Some basic general info...
- I have budgeted $2,000.00 for this computer, the current sum is a little over $1,700.00 before taxes in an effort to give the build a little wiggle room.
- The only vendor I'm using for now is newegg. I don't feel particularly loyal to newegg, it's just where people I know have bought stuff.
- I intend to use this computer primarily for gaming (max settings), secondarily for playing media, and a bit for other miscellaneous stuff.
- I will probably overclock this computer. I plan to run it for a bit at the cpu's default settings and see how things go. If it runs amazingly I may leave it alone.
- My list of parts doesn't include a 3rd party thermal paste (which I suspect I'll need it if I overclock it), but my brother has some stuff I can use if an when it becomes necessary. I don't know the brand though.
- After checking other threads pertaining to new builds I've noticed that I seem to be spending less on a video card than other people. I do not yet have a sense of how much I should spend on a given component for a given budget.
- I've also noticed that the storage device that I intend to buy has less space than the devices other people have bought (500 gig vs. 1.5+ terabytes). The last computer I owned only had 150 gig and I never reached capacity, so I suspect I will not threaten the capacity of my new hard drive.
- The ssd is meant for the os and some other programs that I'll probably use a lot. The other hard drive is general storage.
- Any equipment not mentioned here is not yet a concern (mouse, keyboard, etc.)
- A calculator on newegg calculated that I'd need ~500 watts to power this build. Is the 630W power supply too much?
parts list:
motherboard: ASUS P9X79 LE LGA 2011
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131855
cpu: Intel Core i7-3820 Sandy Bridge-E 3.6GHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115229
video card: EVGA 02G-P4-3660-KR GeForce GTX 660 Ti
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130809
os: Windows 7
ssd: SanDisk Ultra Plus SDSSDHP-128G-G25 2.5" 128GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16820171740
hdd: Seagate Expansion 500GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16822178113
memory: Kingston HyperX Black 16GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16820104361
case: Corsair Obsidian Series 650D (liked what I saw in the newegg video)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139006
power supply: RAIDMAX HYBRID 2 RX-630SS 630W ATX12V V2.2
http://www.newegg.com/Product/Product.aspx?Item=N82E16817152035
heat sink: ZALMAN CNPS12X 120mm
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118097
optical: Pioneer Black 15X BD-R 2X BD-RE 16X DVD+R 12X BD-ROM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827129074
monitor: LG EB2242T-BN Black 22" 5ms Widescreen
http://www.newegg.com/Product/Product.aspx?Item=N82E16824005343
Thank you for your input.
parts list:
os: Windows 7
