- Sep 11, 2005
Hey fellas, I bought this setup about almost 2 years ago and you helped me set it up then (see hehe http://www.ocforums.com/showthread.php?t=411587)
and now I'm starting to get some pretty bad FPS in games and I don't have the ability to go all new yet, in fact i bought a house and a new car this year so money is indeed tight, my question is does anyone know what I can max out my CPU to on this particular mobo, my system is extremely rock solid and I have a Geforce 7800 GS OC which I love but like I said my FPS had been suffering and I wanna see if I can put a "band aid" on this problem for awhile.
This is what SiS Sandra says my motherboard is: (Sorry for the spam I dont know exactly what is relevant)
SiSoftware Sandra
Mainboard
Manufacturer : Gigabyte Technology Co., Ltd.
Multi-Processor (MP) Support : 1 Processor(s)
MPS Version : 1.40
Model : nVidia-nForce2
System BIOS : 03/29/2005-nVidia-nForce-6A61BG0QC-00
Chipset : nVidia nForce2 ICP
System Memory Controller
Error Correction Capability : None
Number of Memory Slots : 3
Maximum Installable Memory : 1.5GB
Bank0/1 - A0 : None None None None DIMM 1GB
Bank2/3 - A1 : None None None None DIMM 1GB
Bank4/5 - ÃËh : Empty
Chipset 1
Model : Nvidia Corp nForce2 AGP Controller
Revision : M2
Bus : DEC/AMD EV6/HSTL+
Front Side Bus Speed : 2x 167MHz (334MHz data rate)
Maximum FSB Speed : 2x 200MHz (400MHz data rate)
Width : 64-bit
I/O Queue Depth : 8 request(s)
Maximum Bus Bandwidth : 2672MB/s (estimated)
Chipset 1 Hub Interface
Type : HyperTransport
Version : 0.10
In/Out Width : 8-bit / 8-bit
Logical/Chipset 1 Memory Banks
Bank 0 : 1GB DDR-SDRAM 3.0-3-3-8 (tCL-tRCD-tRP-tRAS) CR2
Bank 2 : 1GB DDR-SDRAM 3.0-3-3-8 (tCL-tRCD-tRP-tRAS) CR2
Supported Memory Types : DDR-SDRAM
Channels : 2
Memory Bus Speed : 2x 200MHz (400MHz data rate)
Maximum Memory Speed : 2x 200MHz (400MHz data rate)
Multiplier : 6/5x
Width : 64-bit
Memory Controller in Processor : No
Power Save Mode : No
Fixed Hole Present : No
Maximum Memory Bus Bandwidth : 6400MB/s (estimated)
Memory Module 1
Type : 1GB DDR-SDRAM
Technology : 16x(64Mx8)
Speed : PC3200U DDR-200
Standard Timings : 3.0-3-3-8 (tCL-tRCD-tRP-tRAS)
Date of Manufacture : Saturday, December 25, 1999
Memory DC Line : 2.5V
Set Timing @ 200MHz : 3.0-3-3-8 (tCL-tRCD-tRP-tRAS)
Set Timing @ 167MHz : 2.5-3-3-7 (tCL-tRCD-tRP-tRAS)
Set Timing @ 133MHz : 2.0-2-2-5 (tCL-tRCD-tRP-tRAS)
Memory Module 2
Environment Monitor 1
Model : ITE IT8712F LPC
Version : 7.00
Mainboard Specific Support : No
Temperature Sensor(s)
Board Temperature : 35.0°C / 95.0°F
CPU Temperature : 36.0°C / 96.8°F
Auxiliary Temperature : 69.0°C / 156.2°F td
Cooling Device(s)
Auto Fan Speed Control : No
System Fan : 3444rpm
Voltage Sensor(s)
CPU DC Line : 1.71V
Aux DC Line : 2.74V
+3.3V DC Line : 3.18V
+12V DC Line : 11.92V
-12V DC Line : -4.46V
-5V DC Line : -2.04V
Standby DC Line : 3.41V
Battery DC Line : 2.93V
AGP Bus(es) on Hub 1
Version : 3.00
Speed : 4x
Maximum Data Transfer Rate : 8x
Fast-Writes Enabled : No
Fast-Writes Support : Yes
Isochronous Mode Enabled : No
Addressing Enabled : 32-bit
Aperture Size : 64MB
System SMBus Controller 1
Model : nVidia MCP2+ SMBus 1
Version : 0A.01
Advanced TCO Mode Enabled : No
Slave Device Enabled : No
PEC Support : No
This is the CPU that I have in there atm:
SiSoftware Sandra
Processor
Model : AMD Athlon(tm) XP 2800+
Speed : 2.08GHz
Model Number : 2800 (estimated)
Cores per Processor : 1 Unit(s)
Threads per Core : 1 Unit(s)
Package : Socket A PGA
Multiplier : 25/2x
Generation : G7
Name : Duron M10 & Athlon MP/XP (Barton/Thorton) 130nm 1.8GHz+ 1.6-1.65V
Revision/Stepping : A / 0 (0)
Stepping Mask : A2
Core Voltage Rating : 1.650V
Maximum Physical / Virtual Addressing : 34-bit / 32-bit
Native Page Size : 4kB
I cant find any info anywhere that tells me fore sure what I can upgrade my CPU to, I would greatly appreciate any help or options you could suggest, also if you need more info or anything i can try to find it!
Thanks fellas!
SiSoftware Sandra
Mainboard
MPS Version : 1.40
Chipset 1
Revision : M2
Width : 64-bit
Version : 0.10
Channels : 2
Multiplier : 6/5x
Width : 64-bit
Memory Module 1
Memory Module 2
Version : 7.00
Cooling Device(s)
Voltage Sensor(s)
CPU DC Line : 1.71V
Aux DC Line : 2.74V
Version : 3.00
Speed : 4x
Version : 0A.01
PEC Support : No
SiSoftware Sandra
Processor
Speed : 2.08GHz
Multiplier : 25/2x
Generation : G7
Stepping Mask : A2
Thanks fellas!
