So here's my Build, strictly for gaming and VR (Vive or rift?????)
Hardware
Thermaltake Core P5
ASUS Sabertooth Z170 S
Intel core i7 6700k skylake quadcore 91W
Crucial Ballistix Sport LT 2400 16GB
ASUS 1080 ROG STRIX
Crucial MX300 m.2 275GB SSD
Thermaltake RGB 850W Gold Power Supply
Cooling
EK Revo D5 PWM Pump
EK ASUS Z170S Monoblock
EK 1080 STRIX GPU Block & Backplate
FrozenQ Novacore reservoir (waited 2 months for this, disappointed with quality & will probably switch soon)
Aquacomputer 420MM Airplex Radiator
Thermaltake RGB 140MM fans x3
Problems
So I decided to cut costs on the OS & try linux out for the first time. Going Ubuntu cause its the most popular & I'm just trying to get everything running before I start messing with different version of linux. This is my first build by myself, & first watercooled computer.
Once I figured out how to get all the Air out of my radiator(waited 12 hrs for leaks too), I turned on the computer & started getting into the BIOS, had an error code about CPU fan since nothing was connected & had to disable that. I set the Sata1 to M.2 for my SSD
hooked up my disc drive & tried to Boot OS off a USB
I put the motherboard disc in & tried to run it but got a Partition configuration error message: WARNING:using suspect partition Pri[1] FS 0c: with calculated values 0-2-3 instead of 512-1-0
So thoughts on how to fix this and get things rolling? Am I going about installing the OS properly? I tried to boot from the USB drive & nothing will happen just blank screen, There is a fair bit of music on the USB, not sure if this would cause any interference. I've also not connected it to the internet yet, could that help get the proper configuration going?
Hardware
Thermaltake Core P5
ASUS 1080 ROG STRIX
Cooling
EK Revo D5 PWM Pump
Problems
